Tire Size
Thanks Eagle!
She is going to be my DailyDriver, not a trail rig, once I get everything running smoother. However she will not remain totally stock. I am going to put a 3" lift and some 31's under her.
You don't need a 3" lift to run 31s. In fact, you don't need any lift to run 31s if you use factory Jeep rims, although the front tires look a bit cramped under there. I would seriously consider going with around a 1-1/2" to 2" lift. It'll drive a lot nicer than a 3" lift and be more useful because you have easier access to the cargo box.
My '88 had a 4" lift when I bought it and I ran it with 31s. I hated it. I finally removed the lift and swapped it to an XJ guy for a spare engine and tranny. Best thing I ever did for that truck. It is SOOOOOOO much nicer to drive at stock height I can't even begin to describe the difference.
