reverse lights do not work
the truck has been completely dissasembled
Assuming your "re-assemblying" the truck??
First check the fuse box, IIRC there is a 7.5 amp fuse for the back-up lights in the box. If it an automatic, you need to check the netural safty switch, if it a manual, there is a back up switch on the drivers side of a BA10 with 2 wires.
If that all falles, then you need to check the rear connector on the driver side just inside the rear bumber, and then to the rear light them selfs.
