89 Comanche 4.0 starting problems
The story is I had the batter charger on. It wouldtn't start. I pulled that ele lines on the map and the vacum. Still won't start. Now I just pushed the vavle on the fuel rack, then went to try to start and it did.before I started it I did check all plug wires and even push down and moved the injectors back and forth.
Then went to start it and the 1st trun of the key it kicked over.
Here is what I need to know, and that my friends is the problem. What should be my next step? So I could get it fix.
lennyk
I may have left out the idea that it wasn't starting. On / Off
'Two days ago it wouldn't start. Then I put the battery charger on and later that day it started. The next day it wouldn't start all day. It would turn the engine over without starting...Now before i answered your question I went outside and started it right up....What I was hoping for is that answer telling me you should check something else. The fuel line dump a little fuel the first time I did it, that was the other day. Today a much bigger flow came out when I bleeded it.
okay so start with these three things
1. Air- probably not the problem
2. Spark... you got it maybe its not times right and check your order
3. Fuel- inspect fuel filters and test fuel pressure and clean injectors
when you have these all figured out and it still don't run then we gots a BIG probem
