Rear brake issues
Do you know what axle is in your MJ and what XJ axle you pulled the parts from?  The most common axle is a D35 and in that year range they should be the same in regards to the drum brake parts.  If by chance one of them has a D44 or something then they may not use the same parts.
Also double check that all you brake parts and cables are seated correctly.  Reference pictures online to double check everything is correct.
