ok so i did some voltage checks on the ignition coil two wires (yellow) - (green with white strip)
and i did not get what i thought i would see
when the truck is off both lines are dead
then when the truck is running the yellow wire gets 13.4 volts between yellow wire and negative terminal on battery
and the green wire gets 12.7 volts between it and the negative on battery
i also checked to see where the lines run threw the main electrical harness
and they run to the master plug on the right side of the fire wall under the hood
so i think that the yellow is a positive line
because it gets the same voltage as the positive post on the battery would from the alternator
but i have no clue where the green wire would be connected to
or how is it getting the 12.7 volts
Ok I took apart my main electrical firewall plug and toned out where both lines go
the green one goes to the tachometer
and the yellow one goes to the switch on the steering wheel for the key ignition
