Ok so I currently have this electronic distributor on the 3.4
Is it possible to convert it to a vacuum advanced one ?
Could I just buy the vacuum part
Or or is it not possible and I have to buy the vacuum advanced distributor
It might be possible to convert it. But you’ll never find the wiring from the module to the ignition coil . Best bet is to buy new with the model and wiring to the coil
Or buy used
Edit:
Gm only used this style (module to coil wiring) like 1984-6, the older wiring and newer wiring are available but not this wiring.
Sent from my iPhone using Tapatalk Pro
Here a pic of the new Distributor that there sending me
i sure hope its gonna work out ok
its a company in Florida that sells them
www.jminterpart.com
8242 NW 70th St.
Miami FL 33166 USA
Contact us: +1(305)593.10.07
Write us: sales@jmipart.com
Looks correct from what I can see.
You’re close to getting it timed now, might just get that nailed down before trying to swap in a new distributor. I’m not sure how much you’d have to redo to get back to where you are now.
I’m just gonna try to throw this one in and see if I can get it to work
there no real point of tuning in the current one since it’s not gonna stay
does anyone know if my engine is a non interference engine ?
Or is it possible to ruin the engine if the timing is way off ?
None interference .
You should be able to get it close to what it is at the moment just marking where it is at now .
I want to say on of the vacuum line from the carb runs to the distributor .
I’m not going to have time to look at my set up until the weekend , but it’s probably mark in the carb instructions
Yeah I have the correct vacuum line running from the distributor to the vacuum advanced port on my carb
i can hear it work to there’s a bunch of suction when you accelerate
