Ebrake cable
I've installed a Ford 8.8. Previously. I'm working on the brakes and ebrake. I'm having issues with the ebrake cables. I bought the Ford clevis's previously and Dorman 94370 ebrake lines. The ebrake adjuster is bottoming out before the ebrake has any resistance. See the attached.
You can see the part that pushes through the bracket and clips in still has a 1/4" before it bottoms out.
Any suggestions?
What do the other ends of the cables look like? I haven't really looked into it, but I plan on making the same swap, and I think I have heard the issue is at the other end.
