column to floor shift conversion
For those that have done this swap did you use the column cable bracket at the transmission or did you use the bracket off of the donor? The reason I ask is that with the donor fs cable on the donor XJ bracket the cable is about 3/4" short. Another question can the shift lever on the transmission be moved an still function correctly?
The brackets are very different, the MJ column bracket is shorter. Not sure on the cable year 96 or older the yard didn't have anything that new. Going to mess with it some more and see if I can make the column cable work. The shifter ends look like they match up.
