benjy_26 Posted March 9, 2020 Share Posted March 9, 2020 Hi everyone! I was wondering if any of you have used or have seen a Tacoma camper shell being used on a MJ. There's a gent selling a soft topper for an 05 Taco with a 6" bed within 200 miles of me and I was thinking of using it on my '87 SWB MJ. Thanks in advance! Link to comment Share on other sites More sharing options...
thecodemonk Posted March 9, 2020 Share Posted March 9, 2020 My wild guess is that it won't fit perfectly, but might be good enough (depending on how picky you are about the height). Taco bed-racks fit pretty well (based on what I've seen JCR do), so I would assume the width and length might be fine. The hard part is getting the rooflines to match up, from what I've seen others try. 2005 Taco bed dimensions to compare against. http://laghouat-dz.org/2005-toyota-tacoma-interior-dimensions/ Link to comment Share on other sites More sharing options...
benjy_26 Posted March 10, 2020 Author Share Posted March 10, 2020 19 hours ago, thecodemonk said: My wild guess is that it won't fit perfectly, but might be good enough (depending on how picky you are about the height). Taco bed-racks fit pretty well (based on what I've seen JCR do), so I would assume the width and length might be fine. The hard part is getting the rooflines to match up, from what I've seen others try. 2005 Taco bed dimensions to compare against. http://laghouat-dz.org/2005-toyota-tacoma-interior-dimensions/ Thanks! The seller says that this one has a height adjustment. Apparently, it'll go as high as 21.5". I measured the distance from the bed to the top of the roof at a little over that, so it might end up being pretty close. Again, thanks! Link to comment Share on other sites More sharing options...
