itsajeepthing Posted December 7, 2019 Share Posted December 7, 2019 Looking for an e- brake pedal assembly replacement or any idea on how/where to repair it. The teeth on the lever are broken, I tried the welding fix, it didn't work, it wouldn't hold the pressure. Also, I heard that other e-brake pedal assemblies might work on MJ's with some adjustments, anyone knows anything about this? Link to comment Share on other sites More sharing options...
Pete M Posted December 7, 2019 Share Posted December 7, 2019 6 hours ago, itsajeepthing said: Looking for an e- brake pedal assembly replacement or any idea on how/where to repair it. The teeth on the lever are broken, I tried the welding fix, it didn't work, it wouldn't hold the pressure. Also, I heard that other e-brake pedal assemblies might work on MJ's with some adjustments, anyone knows anything about this? after 10 total posts the classifieds will open up to you. Link to comment Share on other sites More sharing options...
