Fastback71 Posted November 23, 2019 Share Posted November 23, 2019 Wonting to swap from a manual transmission in my 1992 jeep comanche 2x4 to a 2000 jeep ax4 to a ax4 from a 2000 Cherokee 4x4 so hasx anyone used a wireing diagram to make it shift or what I'm stumbled a out it would like to make it stsnd alone ' Link to comment Share on other sites More sharing options...
Eagle Posted November 24, 2019 Share Posted November 24, 2019 I'm sure you mean AW4. The AX-4 was the Aisin-Seiki 4-speed manual transmission behind the base model 4-cylinder engines. Link to comment Share on other sites More sharing options...
thecodemonk Posted November 25, 2019 Share Posted November 25, 2019 There's some good info for the wiring on the AW4 linked here: http://www.radesignsproducts.com/tech.html While it's not a wiring diagram, it should give you anything you need to do a standalone or manually controlled AW4. Link to comment Share on other sites More sharing options...
