Turn signal fault
Not the 100% best fix but if it comes down to the connectors in the block being screwed you can splice an inline fuse holder onto the 2 wires for the turn flasher relay and the opposite side of the inline fuse holder connect a male spade connector and then plug the spade side into a open accessory slot on the fuse panel,pop a 20a fuse and it should work, mine is currently setup like this until I get around to completely redoing the fuse panel as the turn signal & radio fuse connectors are long gone from the PO of my truck messing around with them :/
