MWinland Posted September 25, 2007 Share Posted September 25, 2007 My factory tape deck finally gave up the ghost. Does anyone have a diagram of what each wire in the radio harness does? I picked up an early model xj harness, but it isn't the same. Link to comment Share on other sites More sharing options...
mjturtle Posted September 26, 2007 Share Posted September 26, 2007 JEEP Power Memory (+12v Constant) Pink Ignition (+12v Switched) Violet/White Ground (-) Black Illumination Orange Dimmer Blue/White S p e a k e r s Right Front (+) White Right Front (-) Black Left Front (+) Green Left Front (-) Black/Yellow Right Rear (+) White/Black Right Rear (-) Brown Left Rear (+) Green/White Left Rear (-) Brown/White if not that, try this one P o w e r Memory (+12v Constant) Red/White Ignition (+12v Switched) Red Ground (-) Black or Braided Silver Wire Illumination Orange Dimmer (none) Power Antenna Yellow S p e a k e r s Right Front (+) Violet Right Front (-) Blue/Red Left Front (+) Green Left Front (-) Brown/Red Right Rear (+) Blue/White Right Rear (-) Blue/Red Left Rear (+) Brown/Yellow Left Rear (-) Brown/Red Link to comment Share on other sites More sharing options...
