Eagle Posted September 9, 2019 Share Posted September 9, 2019 4 hours ago, Climb over it said: Ok guys thanks so much for everything...I know it's been a minute or two since I've posted but I swapped out the ole cheapo fuel pump for a bosch and now I can drive it! But it does hesitate if I hit gas HARD for a few seconds and then it will back fire and TRY to accelerate but if I ease on the gas it accelerates almost normally...I drove it through my neighborhood and didnt stall it once...I'm pretty sure if I'm easy on the gas i could take it a little further....any suggestions?? oh and I don't have a cat on it...the exhaust is missing from the catalytic converter all the way back.... Put an exhaust system on it, even it it's just an el cheapo glasspack muffler. The lack of any exhaust system may be messing up the O2 sensor readings. Link to comment Share on other sites More sharing options...
Climb over it Posted September 11, 2019 Author Share Posted September 11, 2019 No I haven't checked it yet but I was considering that regulator for sure! I think I'm going to get a scanner and check it first just to see if I get any codes...does anyone know how many pins the port has on this pig? Link to comment Share on other sites More sharing options...
Climb over it Posted September 11, 2019 Author Share Posted September 11, 2019 I do have all new exhaust for it as well I just need to take it to the local shop to be put in...I'm going to scan it this week when I get the equipment and see what I get. Link to comment Share on other sites More sharing options...
Climb over it Posted September 11, 2019 Author Share Posted September 11, 2019 Also my wot switch WAS wired shut before I swapped out the fuel pump...i undid all that and swapped the pump...could there be an issue with that? Should I re-wire it shut? Link to comment Share on other sites More sharing options...
