There are four 31X10.50 R15 tires on stock aluminum rims up front & on aftermarker 15" aluminum rims in the rear.
A previous owner switched out various and added a few (2-3"?) of lift.
I kept the aftermarket rims at the rear and put stock rims up front to match the width of the fender flares.
There is a small amount of rubbing at the front when turning to full lock (at the sway bar).
The wheel size suites the MJ I have.
On several stock XJs I have fit 235 75 R15 tires on both aluminum and steel rims and not had any problems at all with those.
9 hours ago, Jack87manche said:
Does anyone know the widest tire you can fit in the Comanche, I am on a 4.5 inch lift and was wondering if I could fit 32x11.5r15’s?
there are a lot of variables in play here (backspacing, fender cutting, bump-stopping, etc), but given the right circumstances: yes, it is possible.
