tbradway Posted July 9, 2019 Share Posted July 9, 2019 i replaced a leaking fuel pressure regulator which was leaking on the rail and now the gas line connection is leaking. new part came with 2 orings and a spacer to be placed on the line. along with th existing plastic clip. i know it seated with a click but maybe I'm doing something wrong its leaking bad. thanks Link to comment Share on other sites More sharing options...
fiatslug87 Posted July 9, 2019 Share Posted July 9, 2019 Did the o-ring/spacer/o-ring come on a plastic "plug"? You're supposed to push the entire thing into the fuel line, remove the plastic plug and then press the line onto the rail. If there is no plug, place the spacer on the rail then an o-ring, press the line on, remove the line (o-ring and possibly spacer will stay in the line), install the last o-ring in the rail and push the line back on. Make sure to lubricate the o-rings. Link to comment Share on other sites More sharing options...
