tugalo Posted June 10, 2019 Share Posted June 10, 2019 Does anyone know if the back up light switch is different between an XJ and an MJ? I have no back up lights. Have power to the back up switch, but no lights.. if if jump the power at the switch connector, i have lights, so the wiring between the switch and the light sockets is good. Installed new switch, but still no lights. I'm thinking the switch i bought is for an XJ and the B/A10 switch should have a longer nose. 88 MJ, B/A10 tranny Link to comment Share on other sites More sharing options...
Eagle Posted June 10, 2019 Share Posted June 10, 2019 The XJ also used the BA 10/5. Both the XJ and the MJ changed to the AX-15 in the 1989 model year. Remove the switch from the tranny and try pushing the plunger manually. See if the switch works. Link to comment Share on other sites More sharing options...
