Speedometer Gear
I noticed my speedometer was off while test driving. I got new tires and wheels on the truck 245/75r16 and my gearing is 3.08. What is the number of teeth I need to correct the speedometer being off. Also where is a good source to get one for reasonable price?
Thanks
The following website can tell you what gear you need:
http://gojeep.willyshotrod.com/HowtoSpeedoGears.htm
You might try all the usual sources for the speedo gear.   I got mine from Quadratec, but that isn't the only place nor always the cheapest.
The silly gear is really expensive considering what it is (a big custom plastic molded gear), and generally will set you back $25+ new.
