I've been getting this crunchy sound when I accelerate from a stopped position or when I turn. It's hard to describe, but it doesn't sound like a grinding. More like if you cracked your back or knuckles sound. I can feel it too when I'm driving. It's not too loud, sort of muffled. I checked my u-joints and they're still good, I got new tie rods and bushings too. I don't even know where to look next. Thanks.
Figured it out: Turns out my trans mount was bad which was making the exhaust pipe hit the trans bracket when I accelerated.
Jack up each front wheel separately and check for lateral play and/or noise when you spin the wheel. Sounds like a wheel bearing problem.
1 hour ago, Wounded_Fighter said:
Is it only when turning one direction?
No. It's mostly during acceleration, going straight, from stopped.
I'll try. Thanks.
