Trans cooler
I had to replace a leaking radiator so I switched to open cooling using spectra cu1193. I also had to fix the previous owners attempt at installing a trans cooler. I used a derale cooler 13316
 15 feet of -6an braided stainless line
2 M14x1.5 to 6an fittings Russell 670520
Crush washers are needed for the fittings Fragola 999214
The rad fitting size is 5/8x18 inverted flare Russell 640380
I also needed 2 straight 2 45* and 2 90* hose ends.
