Tim118817
Everything posted by Tim118817
  1. The m14x1.5 fittings replace the quick disconnect fittings in the trans
  2. They went in the scrap pile. They were leaking at every connection
  3. I had to replace a leaking radiator so I switched to open cooling using spectra cu1193. I also had to fix the previous owners attempt at installing a trans cooler. I used a derale cooler 13316 15 feet of -6an braided stainless line 2 M14x1.5 to 6an fittings Russell 670520 Crush washers are needed for the fittings Fragola 999214 The rad fitting size is 5/8x18 inverted flare Russell 640380 I also needed 2 straight 2 45* and 2 90* hose ends.
