]Ok guy here is my 87 Mj the Christmas day after the old lady gave it to me.
Stock 2.5 aw4 2wd. dana 35
The plan is full widths, a 78 f150 super cab hd44 and 9 inch rear. 5.13s with 37's on hmmv wheels. That should put wms to wms in the front a 67.5 and rear at 65.
39477262290_418a0fa0ef_b.jpg20171225_101311 by Joshua FInney, on Flickr
39477250370_cdb1719961_b.jpg20171225_101317 by Joshua FInney, on Flickr
40573267184_03fca37a65_b.jpg20171225_101323 by Joshua FInney, on Flickr
40573258164_2317573f5c_b.jpg20171225_101331 by Joshua FInney, on Flickr
27414242068_845c4c8d2a_b.jpg20171225_101333 by Joshua FInney, on Flickr
39477200580_30bc8c6afd_b.jpg20171225_101340 by Joshua FInney, on Flickr
41243764452_8c0cfaf8f7_b.jpg20171225_101343 by Joshua FInney, on Flickr
41286927721_f9e7cfc184_b.jpg20171225_101420 by Joshua FInney, on Flickr
27414023578_cae2269d1b_b.jpg20171225_101423 by Joshua FInney, on Flickr
41286916101_58482bc8fc_b.jpg20171225_101429 by Joshua FInney, on Flickr
The next day I yanked out the 4cyl. and pulled a 4.0l out of a 88 xj.
39477167920_4fba73e0d3_b.jpg20171225_145826 by Joshua FInney, on Flickr
27414174728_fe915ea70b_b.jpg20171226_172122 by Joshua FInney, on Flickr
41286884301_4cac087fa8_b.jpg20171226_172126 by Joshua FInney, on Flickr
26414838507_891612dd76_b.jpg20171227_104959 by Joshua FInney, on Flickr
39477100200_ff969a5939_b.jpg20171228_121250 by Joshua FInney, on Flickr
The engine bay being prepped for the 4.0 swap.
40390171755_21d6b4d5de_b.jpg20171227_221350 by Joshua FInney, on Flickr
40390157705_9e03fd5e25_b.jpg20171230_170256 by Joshua FInney, on Flickr
39477080390_487bc505d0_b.jpg20171230_211438 by Joshua FInney, on Flickr
The donor tranny and tcase is an aw4/np231 out of a 97 xj.
39477065730_4d66609a31_b.jpg20180121_143949 by Joshua FInney, on Flickr
26414685617_498fb92dbb_b.jpgreceived_1547602525294655 by Joshua FInney, on Flickr
They tranny and engine mated and dropped in.
41243637402_4c0d90119f_b.jpg20180128_144645 by Joshua FInney, on Flickr
26414754467_dd5834a8c8_b.jpg20180128_154251 by Joshua FInney, on Flickr
27414050608_fe67323773_b.jpg20180215_113907 by Joshua FInney, on Flickr
I'm going to run and renix intake the block is a 95 with a 95 head. I went though it before dropping it in. I waiting to get a fuel cell so I can fab up fuel lines and a fuel pump. After that I'll finish putting the intake and stuff on.
The axles are going to be a 78 F250 front d44 with F150 hubs to run 5 lugs, to match the 9 inch rear. I got the front housing for FREE with a machined pass side flat top knuckle. I was originally going to run a tnt truss and clayton longs arms. But after a ton of thinking and budgeting, I'm going to run leafs up front. I have a set of stock yj leafs ready to be mocked up.
41286781911_13ebdc8021_b.jpg20180225_161327 by Joshua FInney, on Flickr
40573037564_f9f5c61b33_b.jpg20180225_161331 by Joshua FInney, on Flickr
I have a d300 I'm going to slowly build so when the 231 fails I have a back up. I hoping to be done around thanksgiving. The end results I'm hoping for is the Mj sitting on 37's spool front and rear with 513s.
Well I got the 2wd axle out yesterday. Stuck the leafs in to start the mock up. Got alot of mearsurements so i know what modifications are needed to the front axle. Now just need to order some YJ shackle hangers and a few pieces of metal.
41346419151_2ea12940ed_b.jpgLeaf mock up by Joshua FInney, on Flick
  • 4 weeks later...
Ok finally found time for a little update.
I got the front crossmember built and ready to install just waiting on my shackles to get here.
If anyone has any questions ask away.  I hoping next weekend I'll be to get the front end prepped and installed.
41330329535_38950129c4_o.jpgFront cross by Joshua FInney, on Flickr
41330334225_27bb534ab4_o.jpgfront crossmeber by Joshua FInney, on Flickr
41330332195_0c1cd01f77_o.jpgLeaf perch by Joshua FInney, on Flickr
Lots of tacking in place reinstalling, checking, modifying, rinse and repeat.
42231199181_cdeec60566_o.jpgfront cross6 by Joshua FInney, on Flickr
40423708560_03b4a30145_o.jpgfront cross5 by Joshua FInney, on Flickr
42231199971_612fbf3ba8_o.jpgfront cross4 by Joshua FInney, on Flickr
42231201041_7d6b54c904_o.jpgfront cross3 by Joshua FInney, on Flickr
41509471264_387d0fc0ee_o.jpgfront cross2 by Joshua FInney, on Flickr
41330328155_f06c6958a5_o.jpgFront cross1 by Joshua FInney, on Flickr
