87 fuel pump/sensor module
Fuel pump and sensor inop. Extensive search of the net shows Delphi as only source for fuel pump module. But pics show pickup/strainer and sensor float pointing forward. My unit pickup/strainer and sensor float point to back of tank. Tank reservoir is to the rear of the tank and wouldn't accept  a forward pointing unit.
The Delphi one is a misprint.  It is for the XJ and will not fit correctly in the MJ.  Your best bet is the junkyard or posting a want ad here on the forum.  There's a guy in Indiana who had (has?) several 2.5 senders.
saveeveryjeep is his screen name on here
