JeepcoMJ Posted August 12, 2007 Posted August 12, 2007 what years had it, what years didnt? my 89 has a hp dana 30 front with a vac. disco...
jared Posted August 12, 2007 Posted August 12, 2007 i am pretty sure most if not all had them up unitl 2000 or 2001 thats when they switched to lp
Twisty Posted August 12, 2007 Posted August 12, 2007 All XJs had HP until 2000 then they went to LP. All YJs had HP. All CJs had LP and all TJs had LP.
CWLONGSHOT Posted August 13, 2007 Posted August 13, 2007 Twisty, you forgot a couple.....All MJ's where Hi pinion and all ZJ' and WJ's are LO pinion. :D As I don't believe MJ's ever got the 242 T case, All where a Hi pinion Vac disco for the year 1989... (I know MJ's stopped production in 1992) To expound a bit, all XJ/MJ with the 231 T case made before 1995/96 got the vac disco front axle. If it had the 242 T case it got a solid axle.. but even then, it got the small joints until 1995/6. CW
