Twisty Posted August 5, 2007 Posted August 5, 2007 88 MJ, 4.0, AW4, yadda yadda...not stock, but the brakes are. I can't get the passanger side front to bleed. The drivers side will just fine, but nothing from the passanger side. I thought there was a clog, so I took a bicycle pump, and pumped air through the line. I did this at BOTH ends. I took the rubber line off at the passy side, and pumped air up to the master...which bubbled. I tried to bleed...nothing. Then I took the line dirrectly out of the master, and pumped air through there, and it went just fine. I hooked the line back up to the master, got a few bubbles, then nothing. I've tried the master cylinder from my parts XJ, didnt work. I bench bled the thing...still wouldnt work. My next thought is the splitter that the master leads into...but if I can get air through it, then why can't I get fluid through it? Clog? Is there a valve in there that can go bad? I have a wheeling trip in 1 week, and I need to get these brakes working. The front flex lines, calipers, pads, and rotors are very new. The rear brakes are 100% brand new from the backing plates to the drums. I don't know what to do. Any ideas???
Eagle Posted August 5, 2007 Posted August 5, 2007 Try siphon bleeding rather than pressure bleeding? I've seen those "Mighty Vac" brake bleeder kits somewhere recently, perhaps Auto Zone or maybe even Wal-Mart.
