OEM Fog light switch and bezel in MO p/n 8955001893
schardein
Factory MJ fog light switch and panel.  Not an XJ take off because it would have the defroster switch on the right.  Factory correct unless you have the OEM cargo light, then that switch would be on the right.  I'm including a panel indicator bulb and holder.  Many times, the holder retaining tabs break when removed to replace a bulb.  This one is good, I put it in and out a few times to make sure it will hold, it can be spliced in.  $25 shipped.
Archived
