quick help -- distribution block wire
Need some help on a wiring question. On top of the distribution block, there's the double wire plug (a gray and a black wire).. Which way does it connect? I was fixing some wiring and figured it could only be oriented one way but seems that either way works. Gray or black wire closer to the firewall?
Thanks
'Preciate it sir. I thought that may have been the case but wanted to confirm that. Fixing some electrical issues. I also have a bad short due to a leaking clutch master cylinder :grrrr: . Replacing the engine side 'plug' at the firewall and then splicing wires at the air box. Good chance I'll have question on two :) ...
I'm also replacing the battery cables. Is that a "stick to the manual" job?
