cerial Posted March 2, 2017 Share Posted March 2, 2017 I bought the truck with a 4.7 stroker. Had it for a month and went depth finding with the engine. Went out and grabbed a 93 4.0 dropped it in the truck running the renix system and it is more of a dog then I expected compared to the 4.7. I found someone with a mild 78 355 v8 w edel carb mated to a ax15 and bought that carb to pan, balancer to the front of the transmission. Then I bought Novak mounts,and a new slave/parts to mount it to the bell from AA. I am waiting on various new gaskets(while it's out), mechanical fuel pump, pump to carb line, autofab pins, 454 radiator, and dual electric fans to arrive. I am spending the cash to make this as "bolt in" as possible. The only exception is I am moving the (much larger) radiator to where the tailgate currently is. But that is so I can hide a winch behind the grill and have a flush to the grill bumper. Here is what I need and would like recommendations on. Throttle cable-I want something I can find at a parts store that I do not need to modify. Recommendations on modifying my stock tank pickup/pump.for mechanical pump (I do not want a electric pump/regulator) GM pump to jeep power steering box fittings(where to buy) Waterproof, mud proof, ice proof, heat proof starter/cs130 alternator recommendations (both mounted low) or just buy stock and replace it under "warranty" Link to comment Share on other sites More sharing options...
FrankTheDog Posted March 4, 2017 Share Posted March 4, 2017 Use a stock tank and sending unit out of an 1986 MJ for a carbed setup. Depending on how much horsepower you're putting out it may not flow enough. It was only intended for a 130 hp V6. Link to comment Share on other sites More sharing options...
