strictlyxjs Posted February 5, 2017 Share Posted February 5, 2017 I tried searching...my 1986 2wd mj has the 1 piece brake rotor/bearing combo with the little cap on the end. right now i have the steel wheels with the large hole opening and no center caps. I have the opportunity to pick up these wheels: will these fit with those wierdo rotor bearing combo or do i need something with thr bigger opening. I already know the bolt pattern is the same. Link to comment Share on other sites More sharing options...
HOrnbrod Posted February 6, 2017 Share Posted February 6, 2017 The crusty bearing cap will fit in the hole but will stick out a bit and look bad. Here's an easy fix I did: There's another way if you don't want change knuckles (I didn't). You can't buy the OEM caps anymore, and there are no low profile caps; they will all stick through the hole somewhat. One solution I found is to use Mr. Gasket Chrome Dust Caps. They are just a tiny bit small, but you can cut a strip of aluminum from a beer can and fold it shim it around the inner lip of the hub and they will tap in firmly and stay forever. http://www.summitracing.com/parts/mrg-2485/overview/ They look better than the original dust caps sticking through. Link to comment Share on other sites More sharing options...
strictlyxjs Posted February 6, 2017 Author Share Posted February 6, 2017 perfect. that is the exact answer i needed. ill have to order a set of those! Link to comment Share on other sites More sharing options...
