johnj92131 Posted February 5, 2017 Posted February 5, 2017 Looks OK at one end of the range. How does the resistance change as the float goes thru it's full range of motion? May also want to check the readings with the float thru a vertical range of motion.
Keyav8r Posted February 6, 2017 Author Posted February 6, 2017 Coming in the full write-up on sending unit repair.
