Jeep AM/FM/Cassette Radio 56002467
Minuit
I'm looking for a very specific OEM radio. Part number 56002467. To my knowledge this was the highest level radio in approximately 1988-91 Jeep vehicles. By 1992 it seems to have been replaced by the more common green tinted version.
I need the one on the right. Not interested in the one on the left. Note the black display and no CLK button. When the radio is powered on the display should be green.
I need one in good working order. The cassette player doesn't have to work, but the radio needs to be otherwise functioning. Willing to trade for parts of similar value that I happen to have on hand, just let me know what you need.
It's deff dusty haha. But in the am I will pull it and see if I can put power to it. Threw a battery in and checked the fuse and it didn't power up, but I've taken some wiring out of this mj. So I will try to power it manually and let u know.
Sent from my SAMSUNG-SM-G891A using Tapatalk
4 and 5 should make it turn on (don't know if you'll actually be able to see anything, but on the green faced ones the time will show up), and 10 and 11 should make it light up. The pins are numbered looking into the back of the radio, not the front of the harness plug. Ground is a tab next to the plug.
