Skyryder55 Posted December 16, 2016 Share Posted December 16, 2016 So need some advice. I've got an option to buy a 98 Cherokee. Only 160K kms on it. Body is trashed. Was a rollover. Has a 5 speed. Engine is pulled. Is this a good donor for my 4wd conversion? 1988 mj 2wd is project truck. Link to comment Share on other sites More sharing options...
Skyryder55 Posted December 16, 2016 Author Share Posted December 16, 2016 So need some advice. I've got an option to buy a 98 Cherokee. Only 160K kms on it. Body is trashed. Was a rollover. Has a 5 speed. Engine is pulled. Is this a good donor for my 4wd conversion? 1988 mj 2wd is project truck. Link to comment Share on other sites More sharing options...
Skyryder55 Posted December 16, 2016 Author Share Posted December 16, 2016 Follow up. The Cherokee is $300 Link to comment Share on other sites More sharing options...
Skyryder55 Posted December 17, 2016 Author Share Posted December 17, 2016 Sorry.double poster last response. Great way to up your post count, just have a conversation with yourself. Lol. Link to comment Share on other sites More sharing options...
Siopposition Posted December 17, 2016 Share Posted December 17, 2016 I'd personally say yea it's a good donor. If all ur after is the drivetrain. Sent from my SAMSUNG-SM-G891A using Tapatalk Link to comment Share on other sites More sharing options...
Skyryder55 Posted December 17, 2016 Author Share Posted December 17, 2016 Who knows what the future may hold for this beast, but for the time bring I don't need anything crazy. Link to comment Share on other sites More sharing options...
gogmorgo Posted December 19, 2016 Share Posted December 19, 2016 Won't be a good donor if I get to it first, lol. I can't do anything with it right now, even though I want it. She's all yours. It would be a pretty good donor, yeah. I don't think there's any wiring issues with the manual trans that you'd need to address, plus it would come with the stronger front axle, a sealed-output transfer case, and other good stuff from the later year XJ's. Although if you're also looking to manual-swap at the same time, I think there are some differences in the early and later setups that might require some modifications. But if all you're after is trans, tcase, driveshafts, and axles, you're probably good. FYI you will still need a different length rear driveshaft, and the XJ's rear axle, while probably stronger than your MJ's won't bolt in without relocating the spring perches. Link to comment Share on other sites More sharing options...
