Newton Posted October 17, 2016 Share Posted October 17, 2016 here is a video of what my idle sounds like after a cold start you can hear about 15 secs into the video idle drops about to stall and picks back up and does it again around 1:30 and after running for around 10 mins the drop in idle will disappear any ideas what could be the cause ? https://youtu.be/bGbJe5jxsrI Link to comment Share on other sites More sharing options...
Tex06 Posted October 18, 2016 Share Posted October 18, 2016 Vacuum leak. You have a can of engine starting fluid (ether)? Sent from my SM-G930T using Tapatalk Link to comment Share on other sites More sharing options...
Newton Posted October 18, 2016 Author Share Posted October 18, 2016 i tried spraying carb cleaner around vacuum lines but nothing but i can try the starting fluid...what should i do with it? Link to comment Share on other sites More sharing options...
Tex06 Posted October 18, 2016 Share Posted October 18, 2016 Same thing. Spray around the vacuum lines, throttle body, and any other hoses/rubber fittings. Sent from my SM-G930T using Tapatalk Link to comment Share on other sites More sharing options...
Newton Posted October 18, 2016 Author Share Posted October 18, 2016 Same thing. Spray around the vacuum lines, throttle body, and any other hoses/rubber fittings. Sent from my SM-G930T using Tapatalk What should I listen for? Link to comment Share on other sites More sharing options...
Tex06 Posted October 18, 2016 Share Posted October 18, 2016 Idle speed should pick up. If you're not sure, spray a little in the air filter. It'll have the same effect. Sent from my SM-G930T using Tapatalk Link to comment Share on other sites More sharing options...
