Weird Request (Take Pic Of Your Motor/Vacuum Lines)
Here are some links that might help, check them out:
http://comancheclub.com/topic/43128-vacuum-line-mess-on-a-1987-renix/
http://comancheclub.com/topic/44121-renix-25-vacuum-lines/
http://comancheclub.com/topic/2023-a-couple-25-vacuum-and-electrical-what-goes-where-questions/
And just a hint. Before asking for help try searching for your issue. Most likely it has come up before. Read through the old advice and then if you still need help post and explain what you have already done. For me it works best to google the following : "site:comancheclub.com *** " where you put your issue where the asterisks are.
Post back if the links and searching doesn't help.
