airspeed Posted July 21, 2016 Share Posted July 21, 2016 Ring gap position is like asking what is your favorite engine oil, everybody has a different answer. My Chrysler FSM shows the ring gap position to be inline with the wrist pin and each ring staggered 180. Everything I look at online will show you something different. I open for suggestions. Link to comment Share on other sites More sharing options...
Eagle Posted July 22, 2016 Share Posted July 22, 2016 I'm inclined to think the engineers who designed the engine and wrote the official factory book probably know more about their engine than other sources, but I'm a bit old-fashioned that way. What year (in case it makes a difference)? Link to comment Share on other sites More sharing options...
MancheKid86 Posted July 22, 2016 Share Posted July 22, 2016 it makes sense for a 180 degree split on ring gap 100% in doing so, it reduces the probability of all the ring gaps lining up in the same area, reducing the loss of compression any other degree's will bring the probability factor up. why chance it? Link to comment Share on other sites More sharing options...
Sir Jacob the 2nd Posted July 22, 2016 Share Posted July 22, 2016 I split mine 180, however I do have a 4.0. It was what the factory specified so rather than risk burning oil I set them 180 staggered. I didn't however gap them exactly the same, I chose how much gap I wanted and filed accordingly. My motor runs great so far :thumbsup: Link to comment Share on other sites More sharing options...
Eagle Posted July 22, 2016 Share Posted July 22, 2016 I split mine 180, however I do have a 4.0. It was what the factory specified so rather than risk burning oil I set them 180 staggered. I didn't however gap them exactly the same, I chose how much gap I wanted and filed accordingly. My motor runs great so far :thumbsup: If you didn't gap the rings according to factory specs, how did you decide to gap them? And why would you use anything different from what the factory specifies? Link to comment Share on other sites More sharing options...
Sir Jacob the 2nd Posted July 26, 2016 Share Posted July 26, 2016 I split mine 180, however I do have a 4.0. It was what the factory specified so rather than risk burning oil I set them 180 staggered. I didn't however gap them exactly the same, I chose how much gap I wanted and filed accordingly. My motor runs great so far :thumbsup: If you didn't gap the rings according to factory specs, how did you decide to gap them? And why would you use anything different from what the factory specifies? I used a gap chart from a webiste that tells you how much to gap your rings based on what purpose you are building the motor for (i.e. racing, towing blah blah). All considered the difference was minuscule in how much gap I filed and factory standards. Link to comment Share on other sites More sharing options...
