Fuel mileage decrease or sensor
Having trouble with my truck either burning a lot of fuel or not reading correctly. I have had a few people say that its not reading properly because its not the right tank, FYI it used to be a 2.8L V6 and now its a 2.,5L 4cyl. So its a bigger tank than what its used to but I'm not quite cnvinced that its the sensor. Need advice or ideas. Thanks . :MJ 1: .
Not sure how you are deciding you're using more fuel?
If you're just putting more fuel in when you fill up it doesn't mean anything if it's a bigger tank and you aren't keeping track of distance travelled. Obviously a bigger tank is going to take more fuel to fill.
Did you swap out just the tank or actually the motor? If only the tank did you reuse your sending unit or switch it for one that came with the tank?
