Clutch Pedal Broke
The clutch pedal broken on my 87 MJ.  I removed all the bolts for the pedal assembly but one.  The bottom bolt that connects to the assembly and the clutch master cylinder does not come out.  What is the best way to remove this bolt?  Can the bracket be welded back on without removing the assembly.  Thanks
