gte636p Posted December 27, 2015 Share Posted December 27, 2015 Finishing up a project and I have a core 4.0 (with accessories , engine wiring harness, and computer). Engine was pulled due to low oil pressure (~4lb after 30 min of running). It should make a good build-able core. Includes the renix intake and exhaust manifolds as well as OBD1 intake. I believe I have an OBD1 exhaust as well, not quite sure. The catch: transmission has to go with it. There is nothing, that I know of, wrong with the transmission. It worked well for the 2 hours I drove the truck before swapping things around. Also have a 2WD shortbed driveshaft and bench seat to go. Bench seat will need a bit of work and is missing brackets and sliders. All parts originally from an '89 model. I am in North Atlanta. Willing to travel a bit to give these parts a new life. Link to comment Share on other sites More sharing options...
gte636p Posted January 1, 2016 Author Share Posted January 1, 2016 Motor and transmission have been picked up. Link to comment Share on other sites More sharing options...
banjobill80 Posted January 1, 2016 Share Posted January 1, 2016 I'm in need of part of the harness if availble i only need the right side of the harness that is attached to the firewall and runs along the passenger side of firewall then towards the front fender. the engine plugs into it. Link to comment Share on other sites More sharing options...
gte636p Posted March 20, 2016 Author Share Posted March 20, 2016 Hey, I haven't been back in this section for a while. The harness wasn't around much longer than the motor... Link to comment Share on other sites More sharing options...
Archived
