Brake lights stuck on
91 base 4wd 4.0 stock. Well my master cylinder failed so as I was pulling it off I broke the stud off the brake booster so I also replaced the brake booster. Well put it all back together and bleed the brakes and as I'm leaving for work my wife calls and says I have no brake lights. So I look into it and I have brake lights they just don't go off when I let off the peddle. I've took off booster and reinstalled same problem. Any help would be awesome.
