brake issue
sometimes after stopping hard/quick my truck loses all brake pressure and it takes ~30 seconds of driving/ pumping to build it back up to a normal pedal. I don't notice any leaks anywhere...    I'm assuming its a booster issue but curious on others inputs
I did the MC and booster at the same time. Orielly's has pre 'bubble' flared brake line. I got a 3 foot stick of that and cut it in half, double flared the other side, added the correct fittings and bent it as I went along. So far no leaks and it was my first time :D just make sure you bleed like that link says.
