So here it goes, I'm doing an interior swap on my 91 Comanche. I'm swapping to the newer, 97-01 dash. I'm keeping it a 5 speed, but I'm trying to find a clutch/brake pedal assembly. Does anyone have one? Or would the assembly out of a TJ work? They look very similar, but I really don't want to buy one just to find out it doesn't work. Any advice or idea's? Thanks in advance!
Kyle
I think they're the same, but not sure.  Why replace what you have?  They don't go bad.  If you want to freshen the assembly up, you could paint it and put new pads on it.
The Comanche brake/clutch pedal assembly is different and it doesn't mount the same. MJ assembly is a lot taller, I could modify it to make it work, but I would rather not.
