WJ steering box + tie rod end
I want to swap out my original steering box with a quick steer out of a WJ. I have read that normally you need to remove the pitman arm and use your existing one. At the same time I would like to upgrade the tie rod ends with the bigger ones from a V8 WJ.
So my 1st question: Can I keep the WJ pitman arm on the steering box and transfer over all the front end pieces onto my axle? A full swap if you will.
2nd question: What power steering pump should I get to run the new steering box? I know that hornbrod used an 04 wrangler pump, but that requires changing the intake and pump mounting I believe. I am looking for something that is a direct replacement.
Finally: Anything I should be aware of before starting this swap? Things that are likely to break or go wrong?
Thanks for the help.
It's a 93-98 ZJ steering gear box, not WJ. The WJ box is a different animal. The ZJ Pitman has a 1" drop as compared to the MJ/XJ box, so unless you have higher than a 3" lift, you need to retain your original Pitman arm to maintain the track bar / drag link parallel geometry.
All the ZJ steering parts from a V8 ZJ (track bar, drag link, tie rod) are direct bolt-in swaps and considered upgrades because they are beefier.
Your existing power steering pump will work fine with the ZJ steering gear - been done many times. Even on a Renix.
