LarryH88bt Posted October 10, 2015 Share Posted October 10, 2015 Universal fit fuel injection gas tank Only 16 gallons but it's square(ish) so fitment shouldn't be that bad. Can mount it in the bed pretty easy pending local laws. And as far as I know, if their pump moves the fuel at a high enough psi it will work fine. It's probably the next best thing to a fuel cell. Their tech/install section Thoughts? The dakota swap seems inconvenient. Didn't see any tanks listed on rockauto. Wrecker yard near me is hit or miss and sometimes expensive since they pull parts themselves. Tanks Inc. Link to comment Share on other sites More sharing options...
Eagle Posted October 10, 2015 Share Posted October 10, 2015 Your links don't take me to a tank. Which one of their tanks are you looking at, and where/how are you looking at mounting it? Link to comment Share on other sites More sharing options...
teamsmith Posted October 11, 2015 Share Posted October 11, 2015 What's the goal of this and how is it an improvement over the oe style that can be had for around $140 http://m.ebay.com/itm/Fuel-Gas-Tank-with-Straps-Set-Kit-18-Gallon-for-87-92-Jeep-Comanche-/351353900454?nav=SEARCH Link to comment Share on other sites More sharing options...
LarryH88bt Posted October 11, 2015 Author Share Posted October 11, 2015 What's the goal of this and how is it an improvement over the oe style that can be had for around $140 http://m.ebay.com/itm/Fuel-Gas-Tank-with-Straps-Set-Kit-18-Gallon-for-87-92-Jeep-Comanche-/351353900454?nav=SEARCH Sending unit fail. Can't get another. My tank is fine, it's the sender. I'm on my second one and it's leaking. Your links don't take me to a tank. Which one of their tanks are you looking at, and where/how are you looking at mounting it? One of the 16 gallon, square, universal fuel injection tanks. I'd strap it right in the bed or fab up from brackets and hang it right where the original is. Link to comment Share on other sites More sharing options...
buckwheat Posted October 12, 2015 Share Posted October 12, 2015 Why not get the sender refurbished? Easier fix imo. Or modify a cherokee sender to work in your tank. Link to comment Share on other sites More sharing options...
LarryH88bt Posted October 14, 2015 Author Share Posted October 14, 2015 Guess I'll look into it. Rather just do a race fuel cell and go racing but not there yet. :brows: Link to comment Share on other sites More sharing options...
