Axle mounts.
TheDude
Stock stuff is thin crap metal. Aftermarket will be necessary. There are many options for both.
If you were not aware, this will require cutting and welding.
Have not seen what they offer for upper mounts, but the poly performance LCA mounts are beefy and inexpensive. You will want 5 degree mounts for the lowers. I recommend having both of the lowers done at once.
Other companies I recommend, Artec, Tnt, Ruffstuff, Tnt, etc.
Yeah, I hadn't realized they made aftermarket mounts until a few days ago and ordered a set of lowers with the camber horseshoe.
I can't seem to find any of the upper mounts though.
If you mean the mounts that use the cam bolts. Get a set of cam bolt eliminators. cam bolts suck.
There are a handful of aftermarket companies that make passenger side side upper mounts.
Currie, Tnt, Synergy, Clayton, Artec, etc.
If you get a "stock style" upper, make sure that it is made of at least 3/16" steel and hopefully has an additional gusset.
