reubj Posted August 10, 2015 Share Posted August 10, 2015 While wiring my auxiliary fan I discovered the Diode was missing. The factory parts seems to be no longer available. A suitable replacement can be fashioned from (2) 1N5402 diodes (Radio Shack #2761143). Twist and solder the cathode ends together for the connection to the relay. The separate leads are connected to the A/C input and the Radiator temperature input. Hope this helps. Link to comment Share on other sites More sharing options...
