dkmcgowan Posted August 9, 2015 Share Posted August 9, 2015 Are they all the same relay? the ones in mine looked original, made in canada, and they were all the same exact relay. I had read hear or the cherokeeforum that you need to take them out and put them back in and not mix them up, maybe that is for the HO? I replaced them all with this one. http://shop.advanceautoparts.com/p/carquest-by-bwd-convertible-top-relay-r3177p/3996786-P?searchTerm=relay# Before I replaced the relays, when cranked, my volt gauge always showed 12.5V - 13V, not the 14V I'm used too. I checked the battery and alternator, both good. With the new relays, it's a steady 14V always. I'm guess one of the relays was bad and drawing? I was trying to solve two issues, low/rough idle and hard crank. It fired right up. I warmed up the vehicle, then came and let it sit for 15 minutes, and then it fired right up again! I'm not calling it a win yet, more testing today, but seems promising. I'm assuming it must have been the throttle or B+ relay not resetting the TPS or something. I was hoping for a bad o2 heater relay as well and my rough idle to be fixed, but no luck there yet. Link to comment Share on other sites More sharing options...
Crash Posted August 9, 2015 Share Posted August 9, 2015 Other than the starter relay, which is a silver box, I believe the other relays to be the same. Link to comment Share on other sites More sharing options...
dkmcgowan Posted August 9, 2015 Author Share Posted August 9, 2015 So far so good, I think she is cranking and firing up good now. Must have been a relay. The voltage went back to my normal 13V on the gauge, that must have been me not realizing, but it looks like in the morning my voltage reads a little higher. So that was unrelated. But looks good so far. Link to comment Share on other sites More sharing options...
