Katzer Posted July 15, 2015 Share Posted July 15, 2015 Okay fellas...long story.... 1989 2.5L 2wd. When I first got this beauty it had a hesitation/constant stutter with lack of power during acceleration. It initially stumbles on start up but a short touch on the accelerator and it purrs like a kitten. On acceleration it runs like it is not getting enough fuel or too much. The jeep had sat for a while so I dropped the tank and cleaned it. While I was there I put a new fuel pump in it. I changed the fluids and put new plugs and wires in it. The distributer looks brand new so I left it. That didn't fix it. So I refreshed all the grounds, shiny as a new penny. Didn't fix it. I traced and fingered every vacuum line searching for holes like a 16 year old in a 2 dollar lady of the night house. Found some leaks..Didn't fix it. So I started testing sensors. Everything tested fine except for my Manifold Air Intake Sensor. It was way out of the spec that I found on here. I went to the parts store to find out they couldn't get it. Researched online and yep..its not made anymore. I cleaned the connection and tried to remove it... not gonna happen Cap'n! Its gonna twist off and break. I posted on here and was told to tighten my intake manifold bolts and clean/check connections again. So I did and SURPRISE it was fixed!!!!! Fast forward 3 glorious weeks of smooth 2.5L Comanche drivin'. Was driving home in the rain and the stutter returned. I have rechecked the manifold bolts, the sensor connections, refingered vacuum lines, recleaned grounds, CPS looks clean, took off distributer(it looks new inside also) I have tried everything I can think of. Please help. Link to comment Share on other sites More sharing options...
cruiser54 Posted July 16, 2015 Share Posted July 16, 2015 Okay fellas...long story.... 1989 2.5L 2wd. When I first got this beauty it had a hesitation/constant stutter with lack of power during acceleration. It initially stumbles on start up but a short touch on the accelerator and it purrs like a kitten. On acceleration it runs like it is not getting enough fuel or too much. The jeep had sat for a while so I dropped the tank and cleaned it. While I was there I put a new fuel pump in it. I changed the fluids and put new plugs and wires in it. The distributer looks brand new so I left it. That didn't fix it. So I refreshed all the grounds, shiny as a new penny. Didn't fix it. I traced and fingered every vacuum line searching for holes like a 16 year old in a 2 dollar lady of the night house. Found some leaks..Didn't fix it. So I started testing sensors. Everything tested fine except for my Manifold Air Intake Sensor. It was way out of the spec that I found on here. I went to the parts store to find out they couldn't get it. Researched online and yep..its not made anymore. I cleaned the connection and tried to remove it... not gonna happen Cap'n! Its gonna twist off and break. I posted on here and was told to tighten my intake manifold bolts and clean/check connections again. So I did and SURPRISE it was fixed!!!!! Fast forward 3 glorious weeks of smooth 2.5L Comanche drivin'. Was driving home in the rain and the stutter returned. I have rechecked the manifold bolts, the sensor connections, refingered vacuum lines, recleaned grounds, CPS looks clean, took off distributer(it looks new inside also) I have tried everything I can think of. Please help. Did you scrape the attaching point for the braided strap on the firewall to bare metal? Link to comment Share on other sites More sharing options...
Katzer Posted July 18, 2015 Author Share Posted July 18, 2015 All my grounds are as shiny as i can make them. Cleaned elec connections yesterday and now it runs worse. I think i have a bad wire or connection somewhere. Gonna give it another try this coming week. Link to comment Share on other sites More sharing options...
