CEThomas Posted June 7, 2007 Share Posted June 7, 2007 Anyone with a 91 MJ able to take some photos under the hood so I can use to place the wiring and ECU location??? Link to comment Share on other sites More sharing options...
CEThomas Posted June 7, 2007 Author Share Posted June 7, 2007 Also can use a photo of the diasnostic link connector and where it's located on a 91. Thanks Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 7, 2007 Share Posted June 7, 2007 ECU location w. Diagnostic connector (in red rectangle) Link to comment Share on other sites More sharing options...
CEThomas Posted June 8, 2007 Author Share Posted June 8, 2007 Thanks That is a big help :D On the harness back in the left corner I have two plugs alike where the warsher tank is. I take it one is for the washer pump and the other to tell when the tank is low? Also on the fuel rail I have a wire comming out the front about 2' long with a 4 prong yellow plug on it and a clamp. Can not find anything to plug it into :nuts: Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 8, 2007 Share Posted June 8, 2007 On the harness back in the left corner I have two plugs alike where the warsher tank is. I take it one is for the washer pump and the other to tell when the tank is low? Washer pump: 3 connectors. Fluid low-level sensor: 2 connectors. Also on the fuel rail I have a wire comming out the front about 2' long with a 4 prong yellow plug on it and a clamp. Can not find anything to plug it into :nuts: This is to the O2 sensor. Link to comment Share on other sites More sharing options...
CEThomas Posted June 8, 2007 Author Share Posted June 8, 2007 Thanks, Charles Link to comment Share on other sites More sharing options...
