rockhardzj Posted June 7, 2007 Share Posted June 7, 2007 The 98 XJ I got for parts has a tranny with a spent input shaft. It's an AW4. My buddy has an AW4 out of a 96. I know 97+ XJ's, the ECU will pull tranny codes if the tranny is missing, or disconnected or something. Would just dumping a 96 AW4 into the MJ be fine, as in the ECM will not throw codes, as the tranny is present, and plugged in? Reason I ask this is because within a few weeks, I will be putting the 98's engine, wiring, and interior and stuff into my MJ, and I want to make sure the trannies are compatible. If it's not just bolt and go, can I take the electronics and valve body of the one with the spent input shaft, and put those into the tranny with the good mechanical and good input shaft? Or, should I rebuild the 98's tranny with the 96's input shaft in order to have a single good working AW4? Link to comment Share on other sites More sharing options...
Twisty Posted June 7, 2007 Share Posted June 7, 2007 Are you swapping the transfer case too? Depending on the year of your MJ, it might have a 21 or 23 spline output from the tranny. Renix Jeeps had 21 splines, and high-outputs had 23 spline. Link to comment Share on other sites More sharing options...
87manche Posted June 7, 2007 Share Posted June 7, 2007 the AW4 changed very little. Both of those will have a 23 spline output. put the good trans in, plug it all up and it should work fine. Link to comment Share on other sites More sharing options...
rockhardzj Posted June 7, 2007 Author Share Posted June 7, 2007 I have a 21 and a 23 spline 231's sitting around, so either way, output is not a problem for me. Thanks for the answers! Link to comment Share on other sites More sharing options...
