RescueDuck33 Posted June 25, 2015 Share Posted June 25, 2015 Found a nice donor XJ 91 4.0. Anything I need to know if dropping into MJ. Does 91 and 88 have same trans and transfer case? Link to comment Share on other sites More sharing options...
Megadan Posted June 25, 2015 Share Posted June 25, 2015 On 6/25/2015 at 10:57 PM, RescueDuck33 said: Found a nice donor XJ 91 4.0. Anything I need to know if dropping into MJ. Does 91 and 88 have same trans and transfer case? This would essentially be an HO Swap for your Renix. For the transmission...If auto, yes. If manual, no (assuming both are factory). Search around for HO Swap info. Check Cruisers Tips (I believe it's 17 or 19) regarding an HO Motor into a Renix and/or do a little searching to find some answers. It's out there. Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 26, 2015 Share Posted June 26, 2015 The AW4 output shaft changed in mid-1990 from 21 to 23 splines, so if auto, it matters to the tcase you use. Link to comment Share on other sites More sharing options...
